tschuhly
- 247
- 83
- Nov 6, 2024
York,
Pennsylvania
Hey all,
I cracked open my trans to make sure everything looks good before throwing it in my car and noticed a couple things that I wanted to double check about. Also, it appears it has been apart before since there was black RTV around the case.
1. I noticed on the idler pulley (the small one that sits in the middle) there is a ring that looks like something like a circlip is meant to go there. There was nothing there when I took it off. Is it missing something or is this normal? I'm thinking maybe it's an oil channel or something.
2. A couple of the bearing races that go in the end of the case fell out one I pulled the shafts out. Aren't they supposed to be a little tighter than that? I always thought they were pressed in. Should I get new ones even though these all look good otherwise?
Thanks all!
Thanks all!
