Extra return from FPR
Mikkeees
Aug 30, 2021
Oulu, YK, Canada
Hey. Doing a little bit of a modification on my JDM Evo 4.
I am having bigger fuel pump to feed more horses, and my fuel system operator says i would need also bigger return-to-tank line(?)
How about the fuel fumes canister line? I am removing the canister (already removed in the pic) and this line is not for anything right now. I am going to do an breather for the fuel tank also if needed.
The line with nut is to the fuel filter (i am upgrading it also)
Longer line is for fume canister and the shorter one is the return-to-tank.
Any experience over this here?
you only need a bigger return line if you upgrade to a bigger feed line.
if you ran a -6AN feed line, you can use the stock feed for the return.
