Exhaust gasket to Eclipse 1g nonturbo
Tymon1986
Oct 5, 2011
Warsaw, Europe
Hello Guys!
I need OEM part number: Exhaust gaske between manifold and downpipe with two holes to Eclipse 1g 1992 7bolt Nonturbo I know the 6 bolt has a slightly different.
Thanks!
Thanks, but this gasket is for 6bolt. I need MB687022
MB687021 is for all 2.0l N/T DSMs built from Apr 1, 1990 to May 1, 1994 according to Mitsubishi ASA and has nothing to do with 6-bolt or 7-bolt.
If you already knew which gasket you needed why did you ask?
:dsm:
Because I called the dealer today and they told me that there were two types of downpipe gaskets. I have 1g 1992 7 bolt and MB687022 fit to my car not MB 687021 strange.
ASA's European version shows both MB687021 and MB687022 for the 1G non-turbo chassis -- no differentiation between 6-bolt or 7-bolt.
Hopefully the dealership you spoke with verified the correct part using your VIN, though if the pictures posted in here are anything to judge by, they don't look too far off from each other.
    • Sdcryan1
