Evo 9 pistons on Eagle rods
dsmtalontsi95
268
Nov 5, 2007
glenvile, Pennsylvania
There are a few threads on evo pistons but I want to make sure my set up is ok. I have a set of evo 9 pistons and a set of eagle rods. I want to put them to together and have a fairly nice bottom end. This is for a DD or weekend car. I'm not going to the strip ever weekend, maybe twice a year. I'm going to have an hx35 with 25 psi so I'm looking for about 400hp with room to grow. Now what exactly are the compression ratio's of these pistons in our motor (6-bolt)? I've herd the piston them selves are either 8.8-9 but with our heads with that piston is 8:1. The other thing is I hear some people say turn the pistons around in the block and some say don't, which is it? I did some searching but there is no striaght answer on these.
Chance
Ok, then is there a difference in people using after market pistons on stock rods? Is the pin situation different there?
Yes there is a difference. if you want to run evo pistons, you can use evo rods I think. Or 2g rods without modifying them.
most after market pistons are held in place by a full floating piston and snap rings
Evo pistons/dsm stock piston 1g or 2g have press in pistons. you need a mechanical press to get the pin out of the piston and rod.
sorry for a thread revive, but I was looking into eagle rods on evo pistons and this is all I can find. So if eagle rods will not work with evo pistons, which ones will? or do I have to get a piston/rod combo to upgrade. I currently have 6bolt rods with evo pistons, already machined and balanced and installed on the block, but I read that 6 bolts are at there limit at 500hp, and i want to hold 500 and room to grow. I really cant afford for new rods and pistons
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
