2g wiseco pistons on 1g eagle rods
More than likely, the rods would need to be machined at the top end to make then fit the wrist pins on the pistons.
AUTOMECH01 said:
will that make the rods weaker?
Yes they will be weaker, but probably not enough to cause any trouble. If you plan on pushing the rods to the limit, then it might not be a good idea.
It's common sense. If you remove material it's going to get weaker. People have been modifiying 1g rods to fit 2g pistons since the mid 90's.
You could have a machine shop remove the bushings and then bore them, and then relpace the busshings with the proper size bushings. Although the correct way to do it, it is the wrong thing to do. Just sell the pistons and get the 8.5:1 compression pistons for the 1g rods. All and all it will cost more money to make the rods fit than to buy the proper pistons.
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
