evo 8 head with 420a block
My final note to this thread is that if you've built the block and are running a turbo setup than I'm assuming you have low compression pistons strong rods etc...
Making 400hp on a built 420a is as easy as on a 4g63, I've worked on both and currently own a 420a turbo. The factory head on a 420a has just as good air flow, and even better than a srt4. So the idea of changing it is unnecessary. Cams/Gears, springs/retainers, port & polish, maybe some valves if you feel is more than enough for 400.
Before constantly dreaming about how fast you can go, really think about it. Make a parts list break it down. You got to plant the power too, your going to need tires suspension etc...
There's no reason to say swap the motor in a 420a if your happy with fwd. If you want awd than sure consider options. But I think the op was just going off on a huge tangent with the idea of a evo head and has received enough info on the fact that it can not be done.
Why not just do a Evo 4G63 in the Non turbo Eclipse?
Because no one has ever thought of doing this. You sir might be a pioneer for our platform.
But in all seriousness, Type in "evo swap, 420a" on google and see how many people have actually done it with more proof than a picture.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
