Melbowski
- 95
- 12
- Mar 23, 2008
Reese,
Michigan
As stated in the title I've swapped in the Evo 8 ECU w/MAF and done the initial setup on the Tephra V7 rom: injector scaling/latency, knock multiplier adjustment, fan correction, etc. I've been rolling waste-gate (~10psi) getting everything set: injectors hold within +/- .2 of target AFR at WOT and are within +/- 5% ltft; I've set the knock multipliers per eclipsegsx1736's suggestions of Low 18, Mid 14, High 16, and I'm still seeing a substantial amount of knock (>6 counts), particularly at spool-up.
So I decided I'd throw in some 110 and figure out what's phantom and what isn't; with 110 at waste-gate all my spool-up knock vanished (not what I expected...) and the high-end (5-7k) didn't change at all.
This is where I get confused, I'm moderately convinced that my high-end knock is phantom now, but the spool-up is not. I've read through the Evo 8 swap threads over and over, and I don't see any mention of having to tweak the maps at all; most people are leaning them out up-top if anything. So what's the deal here? How does everyone but me seem to have no issue running the Evo maps as a solid base?
Is everyone having to adjust the timing during spool-up and just not mentioning it? Is everyone running higher knock multipliers? I just can't figure this out; I don't expect tuning to be as simple as plug and play by far, but I don't want to start dropping timing right from the get-go when no one else seems to be. Hortanica even posted that he ran over 23psi with no changes to the stock Evo map, so what's the deal here?
I hope this all doesn't come off as too Newbish, but it's making me crazy! I'd like to have my CEL not flashing at me all the time, and I'd also like my motor to stay in one piece. Sorry for the long post, but I figured it'd be best to be thorough. Thank you all in advance for any help.
. I previously did some logs and tried richening it up a bit as well as pulling a few degrees of timing from the area; it made no noticeable difference. I then decided to change Roms, to see if it would change anything; it did not.
