engine upgrade 2g
mishal_dsm85
Jun 12, 2015
Hermon, Maine
Hi there!
Im new here but i own a 2g dsm since 2002. However, i am working on a new setup for the track. I need your openion on the following setup:
6bolt swap
Fp turbo htz aero dsm86 ball bearing
Exhaust manifold fp
Tail 44 wastegate
Wiseco pistons and manly rods with 2.0 stock 6 bolt crank
Jm intake manifold
Hks cam gears
Ported head with hks 272 cams
Fuel rail and 255 pump
Megan racing coilovers
Driveshaftshop fwd shafts handle 650hp
I will be running motec m4. But im not set with the coil ignition system. I saw sparktech but still doing further research.
Thanks
You need a clutch (southbend) and afpr. And why the dss axles? Super expensive and you don't need them yet. Brian Terhune makes better axles and way better price imo.
Yes i have the ACT twin clutch kit. Oh sh*** i did not know about Brain axles. Yup dss are very expensive. I have placed the order but it has not yet arrived. This Brain dude, got a website?
How much hp you think I can make with my setup and fp dsm86 ball bearing turbo? Also do you have any idea about COPs setup and ignition for the motec m4?
Ya Brian's axles are the ish haha. His web page isn't much but you can contact him for more info http://www.terhuneraceworks.com. I had mine cryo treated for even more strength :). Power wise will all be in the tune and fuel used. i tune my cars with ecmlink, so can't help much with the motec sorry. I'm using a homemade cop setup on my gvr4 and so far is working great :) I plan to add a cdi in the future just havnt got there yet.
Ok gre
ok great, will check this guy website up. I can replace my order with something else. I purchased most of my things from extremepsi. Thanks
