Engine Swap?
Ascension
Sep 10, 2007
S - Town, Iowa
Will one of these engines fit into a 95 Eclipse GST?
Engine code Capacity Configuration
3A91 1124 cc Straight-3
3B20 659 cc Straight-3
4A90 1332 cc Straight-4
4A91 1499 cc Straight-4
4B10 1798 cc Straight-4
4B11 1998 cc Straight-4
4B12 2359 cc Straight-4
4G15 1468 cc Straight-4
4G69 2378 cc Straight-4
6B31 2998 cc V6
6G75 3828 cc V6
Figured it'd go here, if not then please move it.
They all will, although the V6 configuration tends to wobble back there, and if you hit a bump, it's likely to bounce a bit and take out the hatch glass.
When you put any of these in a DSM, be sure to use some heavy plastic under it to catch coolant and oil that's bound to leak out, and it's a good idea to have a sheet of half-inch plywood between the motor and the carpet. You'll find that mighty 3B20 will fit best, if you ever find one.
Terrific First Post, though. :rolleyes:
People seem to have enough problems trying to swap 4g63's with 4g63's.
Just don't do anything stupid, it makes us all look bad...
