Engine shipment damage help?
Quent
4
Nov 3, 2020
Cincinnati, Ohio
Hello, So my mehcanic took photos of my motor from the trailer he did not sign off on it and refused it. From the pictures the palet is destroyed and the zip ties are not all the way strapped onto it. Part of the engine was shown poking through the wrap. If it was damaged would the transporter contacted the place I bought from? I need opinions if this engine is still ok for use. Its on hold at a terminal right now. and it looks like the motor is laying on its side.
chances are if they send it back to where you got if from, the seller will re-pallet the engine and ship it back.
just look it over really good and if nothings broken, there's no reason to send it back.
I looked at the picture and it looks like the cooler line was hacked when they removed it from the vehicle.
Look her over good, my sons motor came on a pallet and had tipped over. It didn't damage anything in his case.
It looks like a 1990 cooler line so check part outs and some of the vendors. I went with AN fittings and line on mine along with a fresh B&M cooler.
