Engine Removal: How To.
96GST96
49
Jun 15, 2011
Gainesville, Florida
1995 4G63:
Just need a refresher on where to start, easiest way to and how to pull the engine. What do I need to unbolt pre-pull, how to do it, etc., Help would greatly be appreicated! Been out of the scene for over a year and having problems! Thanks!
P.S. Where are all motor mounts located on the car as well? :D
Like earlier stated make notes of all connectors, and I would take notes on a note pad or something as well for reference.
Drain fluids, and start unbolting just take your time.
On a 2g all of the connectors are color coded so its pretty hard to mess up. There is one mount next to your battery tray in front of it, one mount next to your timing cover and one in the front and rear.
Take the radiator and fans out after youve drained all of your fluids. Then undo your o2 housing from downpipe. Next take your exhaust mani off with turbo attached. Then remove I/c piping, throttle cable and throttle body elbow. Then loosen your p/s pump, a/c and alternator so you can get the accessory belts loose. Next put jackstands under the front and remove drivers tire so you can remove the crank pulley and pull the belts out. Next unplug electrical connections and tuck them away. Take the passenger tire off next and you will be removing both cv shafts out of the tranny and hubs (it takes a screwdriver in between the cv and trans and smacking the screwdriver hard with your Palm to pop it out of the trans)... look up jafromobile on youtube and he has a few vidoes on how to remove the trans and one on how to pull the motor
1995 4G63:
Go to YouTube and type in jafromobile he has tons of videos about 2gs. Also there's like 2 or 3 videos of him pulling his engine. :thumb:
I have found it easiest to pull the motor out with the gearbox as one.
Must have tools for this job:
1. Blue painter's tape (Label connectors, hoses, and vacuum lines.)
2. Ziplock bags ( to label and organize bolts).
3. Sharpie
4. Beer (After the job is done of course)
Put all the bags in a box so you know where they are. If they are labeled, life will be very easy
Label everything even some of the bolts just so you have an easy time assembling everything and just disconnect every wire and the obvious stuff then hook up your hoist and unbolt the 4 engine mounts and should be on its way out.
Also dont forget to take the axels out
1995 4G63:
Put the car on a lift.
Set engine on sturdy table, and lift car off of engine/transmission assembly.
Everything that connects to the engine and transmission.
how to do it,
Right the first time.
Bring it to my shop, and pay me...
You're welcome.
One in front, one in back, and one on each side.
Like everyone said label all the connectors... The bolts I am not too worried about, a good friend of mine showed me the magic by taking me to a junk yard & paying $10 for about 50lbs of bolts off cars
  • For sale 2g 2G Mishimoto Radiator
    2G Mishimoto Radiator $175 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 4G63 Valve Cover ( No broken bolt holes or cracks )
    Valve Cover ( No broken bolt holes or cracks )* great candidate for powder coat or paint *...
  • For sale 2g 2GB Manul/Turbo Engine Harness
    2GB Manual/Turbo Engine Harness $150 + shipping & paypal fees* wired for 1G CAS, CAS Included...
  • For sale FIC 1650 High Z Injectors
    I have a set of FIC High Z 1650 injectors. They are in great shape with only 500 miles on them...
    • jking29
  • For sale 2g Misc parts
    Have a few things for sale. Open to offers, located in Toronto Canada but can ship- S90...
    • Bedicine
