Engine pull help
If you loosen the drive shaft carriers the driveshaft will slide out a bit, but not enough for you to pull the tcase off. You'll have to loosen the bolts that connect to the diff as well.
There's five bolts holding the tcase to the Trans. If you have an aftermarket downpipe you may need to remove that as well
