Electrical Help Please!
Defiant
DSM Wiseman
34,745
228
Jan 13, 2003
glorious Galt, California
Is your battery tied down? Do you have the positive terminal covered with the vinyl protector so that it can't ground out against the hood or a strut bar?
Sounds like a classic case of poor grounding, or poor contact. Pull your main fuses -on the battery cable- and make sure they're not corroded, and check your grounding points for corrosion.
I searched around and couldn't find a thread with the exact same symptoms as me. Anyways, I need some help hopefully from someone who has had a similar problem as me. The car is a 1997 420a Eclipse RS. The car will start and run fine sometimes but other times I will turn the key and have nothing. No accessories, idiot lights, headlights, door locks, windows, nothing. It is almost as if the battery is totally disconnected. Then I will turn the key on and off a few times and I will get power and it will start right up and run perfectly. My clock on my radio will be reset as if I unhooked the battery. As long as I don't turn the car off, it will continue to run perfectly. I have driven it over 40 miles after getting it started this way with no problems whatsoever. I have a brand new battery and my alternator is putting out around 14V. My battery light usually comes on when I am driving but my battery doesn't lose a charge even after 40 miles of driving. I am wondering if it is the ignition switch itself or perhaps ECU or maybe something simple. I cleaned my battery connections just to be sure and I checked my fuses. I am really stumped. Any help will be greatly appreciated. Thanks.
I had that problem, Started once and a while, but got worse and worse. I'd hear a weird buzzing sometimes. First check the ground and try to find any shotty wiring, there could be a draw somewhere. I even threw a battery charger on it and it always said the battery was charged. As it turns out I had a dead short in the battery (or so i'm told) got a new one and have not had a problem since.
