electric fan wiring help
rideyamaha287
49
Nov 5, 2008
Las cruces, New Mexico
ok guys i got done installng my turbonetics kit and my electric fan wont turn on i got rid of those bulky fans and put one electric fan. I wired it to the exsisting fan harness on the (driver side fan) and now it wont turn on. how do i wire it so it will turn on . if any one has had this problem please fill me in..?
nope im pretty sure the passanger side one is the ac one on the 420a. the driver side is the thermostat fan..
when looking at the connector with the clip on top, the left connection is positive and the right is neg.
yeah ive tried both sides maybe my fuse blew. wanna run a relay to the fan and 2 a switch 12v power so its always on. but i dont know much about relays.
<a href="http://s323.photobucket.com/albums/nn472/diamondrev99/?action=view&current=IMG_2334.jpg" target="_blank"><img src="http://i323.photobucket.com/albums/nn472/diamondrev99/IMG_2334.jpg" border="0" alt="Photobucket"></a>
misc:relay_fundamentals [SymTech Laboratories]
I think you probably just connected the fan to harness incorrectly. There are at least three wires going to the stock fan; ground, power for high speed and power for the low speed. If you only connected the fan to ground and power for the high speed, yet the ECU is only signaling the fan to run at its low speed, your fan obviously won't turn on at all. My solution was to connect both power wires for the high and low speed together...
