Nasty Dream
- 455
- 3
- Aug 30, 2011
Alexandria,
Virginia
I installed a hard intake pipe the other day and noticed that there was a hole in the vacuum line going to the wastegate from my manual boost controller.
After replacing the hose with a hole in it, now I noticed that I'm running very little boost. For the past couple of years, I was getting full boost (16psi) at as little as 1/3 throttle and didn't really know any better. So I never really ever pressed the gas pedal past half.
So I'm really happy to have fixed the hole and can't wait to get the MBC set correctly to about 15 PSI.
I don't really have many opportunities to go WOT in rush hour. And I'm really curious what could have been or what the effects of having the hole there did. Here are the things I think this problem could have caused: Would it have worn out the turbo faster; Making the turbo and air hotter than it should have been; Lost a lot of power; and maybe the engine was running lean?
I don't need any help, so it's not a big deal, I'm just curious. By the way this is the stock turbo.
