1G ECU wires for EGR and barometric are cut on my ecu
Vegas Smith
5,193
3,155
Dec 2, 2002
Houston, Texas
I'm trying to find out the cranking problem on my talon for first time start-up and I discovered these issues:
1)I notice that ecu wire 16 for barometric pressure sensor is cut and dangling. Why would this wire be cut? The car has SD hooked up with gm-iat and gm map hooked up. There is also an aem oxygen sensor under the car as well. This is wire is pictured below joined into a green stock wire:
2) ECU wire 15 is cut and joined to some type power/ground wires and into a small connector that is pictured below:
Can anyone shed some light as to what is going on here? Thanks for your help.
