ecu tuning/ ecu flash help!
dosntknow
41
Feb 12, 2011
Richland, Mississippi
Hey everyone, I'm very new to this so here goes nothing. I have a 95 talon, bought it with a 16g and 540 injectors but it wasn't tuned. So I bought a 99 flashable ecu and tactrix 2.0 cable. I downloaded ecuflash and am borrowing a buddies evoscan software for logging. Now here is were my trouble starts. I hook up the op2 cable and and run ecuflash it see's the cable but won't read my ecu. I'm going to first ask for any and all links to help and I have already read ceddy's first flashed dsm but u can link it here for others. Sorry I'm such a noob and thanks
Ok ordered reflash connector. I will update in a few days, thanks.
ok just so everyone know's i am goin to turn this thread into a write up for the uneducated like me so the more links that anyone can add that would be a wonderfull resource.... also any tips tricks or dont do's will be greatly apreaceated.
ok so reflash connector is in what i didnt understand is once my car is a 95 i dont have a spot to plug it in so refered to http://www.dsmtuners.com/forums/tun...first-flashed-dsm-ecu-98-99-flashing-faq.html and hooked a 2.55mm headphone jack straight into the wiring harness can read now... YAY
i get the same report as the guy did in the above link im goin to crack it open tomorrow and see if my numbers match up to his if so i got got.:ohdamn:
Ok good news... numbers match up it should be flashable... After hours of reserch i have narrowed down the issue, i have to download the right rom definition got to get my buddy to look and see how exactly to do that but i will update tomorrow with the right one.
You don't have the right definition. Ceddy's website has the definition file.
That's what I figured. Just threw it out there though. Everyone has this problem (myself included).
Alright downloaded ceddy Mods put it all where it was supposed to go still not working....
swapped laptops redownloaded ceddy Mods reads and flashes just fine.
Ok here is my next question... There is a Rom file that contains his Mods like, cel on knock. Is there anything I have to turn off before flashing this to my ecu?
ok so did that now my car wont start and it wont let me relfash back to stock..... i turned all the mods off except cel on knock here is a copy of the error i get...
comparing ECU flash memory pages to image file --
[19:33:06.161] seg start len ecu CRC32 img CRC32 same?
[19:33:06.302] LB7 00010000 00003000 D9A66A68 D9A66A68 YES
[19:33:06.317] SB0 00013000 00000200 8687ABD6 8687ABD6 YES
[19:33:06.333] SB1 00013200 00000200 01FA9332 01FA9332 YES
[19:33:06.348] SB2 00013400 00000200 6A95BCAF 6A95BCAF YES
[19:33:06.364] SB3 00013600 00000200 4DB1D41E 4DB1D41E YES
[19:33:06.380] SB4 00013800 00000200 CBDA247E CBDA247E YES
[19:33:06.395] SB5 00013A00 00000200 DC51CD0F DC51CD0F YES
[19:33:06.411] SB6 00013C00 00000200 1048DC04 1048DC04 YES
[19:33:06.426] SB7 00013E00 00000200 31061759 31061759 YES
[19:33:06.629] LB6 00014000 00004000 7B32016D 7B32016D YES
[19:33:06.832] LB5 00018000 00004000 4FE1B7BF 4FE1B7BF YES
[19:33:07.019] LB4 0001C000 00004000 3B2A9E4E 3B2A9E4E YES
[19:33:07.222] LB3 00020000 00004000 0478284A 0478284A YES
[19:33:07.425] LB2 00024000 00004000 0DA8A8A5 0DA8A8A5 YES
[19:33:07.612] LB1 00028000 00004000 93F4BDDC 93F4BDDC YES
[19:33:07.815] LB0 0002C000 00004000 67A6C2B2 9554FEF5 NO
[19:33:07.815] kernel flash enable
[19:33:07.815] kernel blank flash page: addr: 0002C000
[19:33:22.853] WARNING: failed to erase page at 0002C000!
[19:33:22.853] kernel flash disable
[19:33:24.866] interface close
if anyone can help this would be much appreciated
Either send me a copy of your edited ROM or post it up here. You probably deleted some periphery bits you weren't supposed to. Hopefully you didn't brick the ecu.
Now did you actually pull the ecu, open it and check the CPU number on the board? If it doesnt read MH7202F you wont be able to flash it. If not Ceddy has a howto to open the ecu here: http://ceddy.us/h8-ecu-wiki/how-to-open-ecu/
Also what did you have to do to get the 99 ecu to run in your 95? I wasn't aware it was possible to have a 99 ecu run in a 95. The car runs good with the 99 ecu?
ya i have cracked it open already and checked the #s it is flashable acually i already dailed in bigger injectors 550cc but i was runing a liitle lean so i was gonna flash it back to stock figured might as well add ceddy's cel on knock and such....
Check for the the continuity of the flash pin and the power to the obd2 port. Very common for it to be loose and short. Or not make a good connection, mind you voltage drops during a flash process can and most likely will brick the ecu so watch out.
:dsm:
So you flashed the changes to dial in the injectors and it flashed great but then you tried to flash the CEL mods and such and got those errors you posted earlier in the thread?
:dsm:
And ensure good battery voltage as well.
ya im worried my pin was loose at the time of flash i checked it and it looked fine but its not exactly perfect..... i sent my rom to tyler hopfully he can let me know if its brcked or not....god i hope not this shit is to expencive to just be messing it up
So ya bricked the ecu, bit the bullet bought dsm link much easier to use. thanks everyone for trying to help. The issue was the continuity of the pin. loose=fried ecu HA HA
