ECU Flash?
bjmauck
203
Feb 20, 2009
Augusta, Georgia
I just bought ECU Flash from dsm chips and I can't read the stock rom I keep getting error codes. I read some where that low voltage can cause it, so I hooked jumper cables to the beater with it running and still the same result. I have a 99 GSX. Thanks
If you're only plugging the OP2.0 into the OBDII port and nothing else, that's your problem.
The flash connector plugs into the white port next to the OBDII port, and then into the OP2.0. You need this even to pull your ROM off, not just to flash one back on.
Everything should be covered in the ECUFlash thread started by Ceddy.
Thats fine. Just do your research and you'll be fine. If you're going to be tuning with ECUFlash, I highly recommend going on EvolutionM as well as here because the Evo guys have been using ECUFlash for a while. I don't think ECUFlash was even mentioned here anywhere when I started using it just a year or so ago, so I spent a lot of time there for a while. Tuning an Evo with it is pretty much the same as with a DSM.
Thanks. I used the flash connecter and it read it, then I saved and flashed. The car runs, but I still have to adjust it. I tried to log with evoscan and it would check dtc but if I tried to log it would lock up and I would have to close and restart evoscan. Any suggestions?
