ECU resetting
Easiest way to do this is to turn ignition off and pull the bottom right fuse in the kick panel fuse box for 20 seconds or so. Put it back in and there ya go, ecu reset (along w/your radio stations).
You should either disconnect your battery or remove the ecu fuse. Leave it for 10-15 minutes as one or two minutes may not be enough.
Have a flashlight handy, as this also kills your interior lights while the fuse is out.
