aPOS
- 88
- 3
- Feb 8, 2011
Moscow,
Idaho
I was watching a colleague work with his ECMlink, and the person could not get the MAFComp Adjustment (CombinedFT) function to provide a new Template after a cruise in Closed Loop. The Template would always be exactly the same as the initial base settings (0% across the Template above 50 Hz) after logging some cruises. Neither of us are very experienced with ECMlink.
Now, I have frequently witnessed others adjust DSMlink V2, but I have no experience with ECMlinks additional features. My colleague does not have a DSMtuners account, meaning that I am inquiring. Similarly, I enjoy learning more about it.
To the best of my memory, I noticed these settings and events:
1. RPM Target idle at 850 (car idles around there since he has 272 cams in a stock 16g at 18 psi TSi)
2. TPSVolts at idle was adjusted to 0.63v using TPS Offset
3. Global Fuel and Deadtime at 0 (stock injectors)
4. AirFlowPerRev at idle was adjusted to 0.26 gm/rev using (lowering) the MAF Comp Adj % sliders at 50 Hz
5. Base MAF type at Stock (I only glanced at this, but I do not think it was incorrectly at Speed Density)
6. MAFComp, above 50 Hz, all at 0%, yet there is a box checked reading Disable airflow smoothing w/ SD operation (since the car is not using SD, this could be the problem)
7. During the cruises, the Lock in open loop mode box was checked
8. During the cruises, the Disable airflow smoothing w/ SD operation box was apparently checked (like the attachment below illustrates, yet nothing except Lock in open loop mode and Disable airflow smoothing w/ SD operation were checked)
lockecmlinkmode [ECMTuning - wiki]
9. The Lock in open loop mode box was unchecked after the cruises were completed.
I did not want to suggest/perform changing settings that I have no prior experience, or understanding about, in regard to its effect. So, even if my guess about the Disable airflow smoothing w/ SD operation being checked is part of the problem, I had not wanted to change it on my colleagues car. Plus, I had not known why it was (or who) checked the box in the first place.
