ECMLink Bosch 2200cc injectors - 0280158821
I don’t know anyone who has issues with them failing or being hard to work with. I know many who have used them and it’s no different than tuning with any other high z injector that size. Shoot even most FIC injectors in that range are just a slightly modified Bosch injector.
what was your based fuel pressure on that injectors? It will be my first time doing it with big injectors. I want to run full alcohol only.
Never used them myself, I had a set I ended up selling as they’re way overkill for anything I’m doing. Every car I’ve messed with running those or FIC 2150s was set at 43psi base pressure but that was for 93 octane pump gas and e85, I couldn’t tell you a thing about running straight alcohol. In fact, I’ve never really seen anyone doing that with these and unless you’re building an all out drag monster you’re going to be trailering to and from the track and tearing down and rebuilding a few times a season I don’t even see that being practical let alone making any sense.
You can daily 100% alcohol, take a look about Brazil's builds, alcohol is the best fuel. Indeed there are some methanol 100% street cars out there. No more knock ever
