Bosch injectors
As everyone above me has already stated - go with Fuel Injector Clinic. They have proven to be the best already.
I'm running e85 not pump gas so as long as there good on e 85 I will stick with them
Are you going to be tuning this yourself?
If so depending on your knowledge of tuning this may not be the best call... .
What are your goals overall? What kind of power goals do you have?
Might be a better Idea to go with a Bluemax Injector depending on what your goals are something smaller than 1550-1650 would be easier to tune for you and better suited and not oversized .
Though 1600's are meant to run on LNG and won't like the low duty cycles you need to run on Gas E85 is better but If you are looking for a Injector for a car only seeing the track Vs a DD it would be a big factor to add in to the mix.
My point here is that if you don't have you head in this 1000% it might be a bigger headache then it's worth. Best I can say is While I Personally would tune them for someone. I wouldn't ever recommend them if buying Injectors. They are one of the things you really don't want to cheap out on... .
STM is tuning the car for me, and it's not a dd at all it won't see the streets much as it has a 8.5 cage in it and the lack of e85 in ohio so it's a track car but I believe I'm going to go with the 1650's from fic they seem to do a good job
Oh okay, Keep in mind it is always still a good Idea to size things accordingly to your power goals while it's nice to have room to grow. If you are not using the Fuel there is a point in trading off for extra room over a better behaved injector is not worth it...
Regudles pretty sure most will agree here that you can't go wrong with a Set of FIC injectors.
PS, Might take a look around the classified there are always quite a few people around going bigger :)
