ecmlink boost control
johng96gst
101
Jul 16, 2011
Westport, Massachusetts
I will be getting ecmlink v3 within the month and was wondering if anything extra is needed for the boost control use? I have the apexi avcr controller now and was going to sell it, but before I do I want to make sure I dont need the selenoid or anything like that before i get rid of it. Or should I be running both? Also, I have multiple sets of injectors with various sizes from evos to rc that are in the 700 range to pte that I believe are 1000s. I should be able to throw the larger injectors in and be able to control the fuel and dial them down, correct? Just curious so I know how to order the it correctly. Thanks
im using the 3 port BCS that Ecmlink sells on their site. it works well once you understand how to use it.
-Shane
Someone wanna explain how to boost control works? Lol I've been trying to get it to work and im not sure what amount to put into each gear.
Dial it back if you dont like a peaky torque curve, or if you spin the wheels. Im in the process of tinkering with mine now.
You used somone elses map? You should prollly just follow the instructions on the website, there pretty clear and will help you dial it in much better.
