ECMLink auto adjust TPS???
Raymond1927
240
5
Mar 9, 2009
Wasco, California
I have a problem with trying to auto adjust my TPS off of my ECMLink V3. With the vehicle off I press the gas pedal completely to the floor board, then let off I right click to pull up options then click on TPS auto Adjust I click on it. And on my screen it say to I don’t have 3.25v of full throttle and even with manually adjusting my throttle linkage to the max that I can and manually adjusted my TPS to .63 and still can’t get it to get to 3.25v over that .63v. so that’s a 3.88 total I don’t know if I calculated that right. Any help would be great.
Your post is a bit confusing, hopefully I can clear things up for you though. The TPS Auto Adjust tool is used to adjust your ThrottlePos value, not the TPSVoltage value. TPS Auto Adjust will get your logged ThrottlePos at 0% when your completely off the throttle and 100% when its mashed to the floor. The TPSVoltage value should be at 0.63v at idle and 5v when the gas is all the way to the floor.
So whats the problem here? From your OP I'm not sure what your asking but hopefully with the above info you can clear it up a bit.
:dsm:
