Adjust TPS to work with keydiver dsmchip stutterbox
bskills
53
May 11, 2008
Jersey City, New Jersey
I did a 6bolt swap with my 95 GST. I recently installed a DSMCHIP stage 3 chip. My stutterbox don't move from the preset RPM of 4000. I was told that my TPS will need to be adjusted so that when I tap my gas pedal, I would be able to select from the 5 preset RPMs for launching. Any help would be appreciated. Pictures will be nice too.
Just to be clear, once I adjust the TPS to get 100% throttle, the stutterbox should work. I have been tapping the gas pedal while the key is in the on position, but it stays at the first position on my boost gauge.
You want your tps adjusted so that you get 100% throttle. Also you just need the key on the "on" positon and just press the gas and it should change rpm launch.
Wrong.
You have to adjust the TPS per the FSM. That involves putting a feeler gauge between the pulley and fixed speed adjustment screw and then set the TPS to the point where the internal IPS switches on and off.
Either the IPS is never switching right now or there is a problem with your TPS. People do stupid stuff like swap in a 1G TPS or a 1G throttle body and don't put the 2G TPS back on.
