ebay rebuild kit
Insane20
545
11
Jun 12, 2012
Natrona Heights, Pennsylvania
Im rebuilding my 6 bolt this winter, im just doing a stock bottom end rebuild with a sim stage 1 head and arp hardware.
Question, would you use this rebuild kit for a stock rebuild?
http://www.ebay.com/itm/360320376272?redirect=mobile
Im not planning on using the belts, timing stuff, water pump or valve seals. But the pistons appear to be npr, and the bearings are kings. Any input would be appreciated. Thanks!
seems decent i wish they still had the one i used by topline i talked to them personally and they guaranteed me the gaskets and pistons and everything would hold up to 600 hp and i think i only paid 350 for it all whats in your package if i could i would try and find one of those but that one to me dont look to bad
you do realize that the kit in the link is for a non turbo 4g63 right?
unless you plan to run an n/a motor find another kit.
if your doing an n/t build The kit looks solid for a basic build, but I would not trust the timing components in the kit or the seals.
If you intend to do a stock 6 bolt turbo 4g63t rebuild, you might want to give these other turbo rebuild kits a look over.
http://www.store.partsdinosaur.com/page18.html
http://www.amazon.com/Evergreen-OK5005L-Mitsubishi-Engine-Rebuilding/dp/B007P73D6O/ref=au_as_r?ie=UTF8&Make=Eagle|41&Model=Talon|342&Year=1990|1990&carId=1&n=15684181&newCar=1&s=automotive&vehicleType=automotive
