e85 wideband
byebyev8
344
Jun 17, 2004
kenosha, Wisconsin
I have a older plx m300 wideband that I still haven't hooked up yet. I'm running e85 and want to hook the wideband up. But i know the lowest it'll read in a pump gas afr is 10.1 af which is 14.1 for e85 which is to lean. So how will i ever know what my afr at wot is on e85.
If you leave the gasoline settings for the wideband (which most people do), you tune it like gas AFRs. The wideband doesn't KNOW the true AFR, it knows lambda/stoich, that is converted to an AFR number by using the stoich value of the fuel (14.7:1 for gas, E85 is 9.765:1). 10:1 gas AFR on E85 is too rich for it to even run decent (6.6:1 E85 AFR). You'll just shoot for say 12:1 AFR @ WOT, or whatever you like to tune for; cruising will still show the normal 14.7:1.
So its not like tuning a chip were you set the afr 8.1 for e85 in order to get a 12.1 afr.
Ok i understand now. I thought the wideband would read at the true e85 afr which would always be to rich to show up.
