DSMlink idle rpm and use of fans
Atuca
Supporting Member
1,145
303
Jan 6, 2007
Central Valley, California
Hey guys hopefully this is a easy fix.
I got a 2g with DSMlink, have had some over heating problem with my ETS FMIC (4 inch core >.<) so I threw on my fans to run at all times.
Well I am looking to upgrade the car a bit and was going over some things, when I realized only one of my two fans were working! I rewired the fan and now they both come on like they are supposed to (all the time as set with DSMlink)
Ever since that my car idles at 1250 rpm (the first mark on the rpm gauge) but if I turn my A/C on, it idles at 750 rpm, which is what it is set at. TPS voltage is set correctly, nothing was changed in DSMlink, only my rewire. Is it possible to wire it wrong, is the A/C just a coinincidence, what is the story?
Bottom line: I want my car to idle at 750 rpm, and it isn't. What should I do?
Thanks ^_^
You know I have the exact same problem, and it's still there to this day. After I put in my aluminum radiator and slim line fans, wired to run like stock fans, the idle is about 1000 rpm, even though my TPS voltage is 0.63 (DSMlink verified), base idle is set to ~800 rpm with the BISS, but the car keeps the engine at ~1000 rpm, and it will drop to ~850 with the AC on. If anyone can offer us some advice, it would be helpful.
Yea, same here, everything is set correctly in dsmlink as far as tps, voltage, rpm limit, ect. Still don't know what else to do but live with it.
