ECMlink DSM link help /tuning
Andranik
109
Nov 5, 2010
Brockton, Massachusetts
hey guys i just finished putting back together my car ...i need some help figuring out why my car wont idle and i checked for leaks ...other than a lil oil leak from VC and some coolant from the container i think it has a small crack in it everything else checked out okay ... i got it to start and run but it barely idles and runs like crap sputtering and bang bang bang from exhaust... im a total noob at tuning but if someone can help me get a base tune so the car runs right so i can at least drive it to the tuner please and thank you heres a log of my tune from what i could understand from the ecmlink videos... i cant get my airperrev done and timing seems out of line too ... i have 950cc fic 20g turbo stock maf
i also have hks 272 cams i know that changes airperrev thing
Mafcomp looks really odd, should be smooth. airflowperRev should be around 30 with the cams. Attach a log of the somewhat idle, the file given was just the config
Oh and confirm a boost/vac leak test before tuning.
What's blt and I will post a log of it running in a bit just got to work :(
hey guys here is a log of the car running well somewhat running please help me out
what's up with the timing.? looks strange tooo....
WTF if anything I like to add timing not take it away, but that would be looked at later since the car cannot even idle at the moment. Andranik zero these for now.
Did you hold the idle up that high? Looks like the o2 sensor is dead since you locked it into open loop yet its still not cycling.
Yeah I was holding the idle up it wouldn't stay on on it's own you think a dead o2 could cause this ?
1. You might have blown your sensor ground (guessing by the -74* coolant temp). This is caused by an issue with the front o2 sensor grounding out. Pull the ECU and check this out.
2. Test the ISC (link in post #7).
If 1 and 2 test out ok:
3. Not sure why you raised timing in the lower RPM's. If I were you I'd zero out the timing sliders.
4. Take it out of closed loop and grab an idle log as best as you can. This way we can see what's happening with your front o2 sensor.
It looks like you're using an old firmware version of v3. I'd suggest upgrading to the newest.
http://www.ecmtuning.com/apps/firmwareupgrade
Okay I'll pull out the ecu and check that tonight thank you guys for the help illl keep you guys updated when I Check that
hey guys the ecu checked out okay i still cant the car to run right :( i have another log i had the car running for a bit can you guys please help
2shared - download running.elg
