2G dropping oil pan to put a new oil pan gasket
Incase you want to know what youre looking for ;) It might be a little pricey compared to other sealants....but WELL worth the extra few dollars
I have used several Kind of RTV, but I went with Gray because it gives a better Stock Look.
When I was using red RTV, Theeeeeeem, the RTV was the first thing I always see when opening the Hood:ohdamn::ohdamn:, and saying that I always clean very well the excess RTV, I even use a wet towel with gasoline to clean all the surrounding area.
However, I have never had any bad luck with any of them, but I always clean and dry very well the area.
The Right Stuff by Permatex. Oreilly and AutoZone carry it
^ THIS
I bought a brand new oil pan for my motor when I was assembling it. I had issues with it sealing and pulled it twice. After using Grey RTV with issues, I tried "The Right Stuff by Permatex" and the pan sealed great and haven't had a leak since. Geat a nice solid bead all the way around the pan and don't skimp on it, better to have too much than too little. Wait til it starts to get a little tacky and then put it on, get all your bolts started and then go around and get them all hand tight, then go back and torque them all down to spec.
I thought I had read somewhere that on some cars the clearance between the oil pickup and the bottom of the pan is a critical tolerence. It was probably on a forum for one of the non dsms I have owned over the years. Is that something that has ever caused anyone in the dsm world any problems with oil pressure or anything?
