420A Oil Pan Gasket Question
Kyleb2021
97
15
Nov 13, 2021
Lansdale, Pennsylvania
hello group my 1999 Mitsubishi Eclipse 420A motor I just redid the oil pan with a new gasket a few weeks ago and I want to take off the oil pan again and do some more internal gasket work on the engine my question is if I take off the oil pan can I reuse that gasket or do I need to go get a new one? also the motor has never been started or run on the new gasket as I am still doing work on the engine.
As long as its the factory style gasket where its rubber molded over metal you'll be fine. If it was a cork type gasket you'll want to replace it
its sure is rubber gasket so ill be fine thank u so much for the feed back
