1G Does this look like OEM harmonic damper
AWD-Tony
6,787
3,750
Sep 11, 2017
Cincinnati, Ohio
I ordered an OEM damper. Does this look oem?
Thanks
Tony
Reminds me of a Dorman unit Tony, but I have used them also and not had any problems. Periodically checking it just to make sure though. I don't know how much difference there is between a OEM and the aftermarket stock units, TBH.
I have a new Dorman at home, I will try to check it out and give you a picture later.
Thanks, Marty! Says oem Chrysler??? And it just came in a plastic bag
I would trust it. I'll still take a picture and post it up for comparison Tony.
This actually came from RockAuto. I have the same one on my Red Talon and had no problems. Close to $50 if IRRC.
I like yours better Tony! :p
Looks like more time was spent manufacturing it!
I'm going by the numbers stamped into the casting. I have 2 stock pulleys here and both have 63 stamped in between the bolt holes and 5M-1202 molded into the rubber.
Edit : Just looked this up real quick. Looks just like yours and the ones I have here. https://machv.com/products/dsm-crank-pulley-kit
