Delta2Echo
- 90
- 1
- Mar 25, 2012
Middletown,
Delaware
Ok...yesterday on my lunch, car made a sound I have never heard before when I turned the AC on. Came and went, knew something was wrong, but nothing I could do. Went to leave last night, started the car, turned the AC on...bam, starts happening again, but worse. I left it running, popped the hood to go see if I could see where the noise was coming from. Before I got to the front of the car, I heard a "pop" and the noise stopped. I immediately went and turned the car off...got under the hood, saw that the belt was no longer on the alternator.
So I was poking and prodding around trying to find out WTF happened. Thought the belt snapped or something, then I noticed the harmonic damper wasn't square to everything else. I got a hold of the belt and pulled it, it moved. Shoved my arm down there and got my hand on it and I could move it around pretty easily, so much so that I could slam it into the frame. I hitched a ride home from work, now I'm back here.
I'm working on getting a tow back to my house 40 minutes from my workplace. I already have an OEM damper coming into Autozone from Dorman. I have a few questions for you guys:
1. How concerned should I be with something really important breaking from this? I know from what I see, the belt didn't make it into the timing belt or anything like that. Engine kept running until I cut it (within seconds of the pop). Is it possible I damaged the crankshaft, bearings, anything like that?
2. I know the OEM part is the best choice for a stock engine. Although I'm not currently racing the car at all, I am running about 13.5 lbs of boost and it's a daily driver...keeping my budget in mind, or lack thereof...is a Fluidampr worth the extra $220 to avoid a huge headache in the future?
3. While I'm doing this, is there anything else that I should be checking, adjusting, or replacing while I"m doing this besides the accessory belt itself?
Any input you guys could give me would be awesome, and greatly appreciated. Thanks in advance!
