Does this HP seem accurate ?
gogogsx
Jan 7, 2011
fort worth, Texas
1994 Mitsubishi Eclipse/Talon-20k invested, tuned to 340WHP on pump gas @16 PSI boost by UMS Tuning. 10k miles on $6,000 engine build. AEM engine management system. Balanced 1991 6-bolt block,SRP 9.2-1 pistons, Eagle rods, Ferrera valves and springs, HKS 263 degree cams, ported and polished head, decked block, metal head gasket, AEM cam gears, Unorthodox engine dampner, Extrude Honed intake manifold, RC 60mm trottle body, RC 550 injectors, AEM fuel rail, SX fuel pressure reg. Walbro 255 LPH pump, Blitz air intake, 20G turbo, XS Engineering front mount intercooler, full 3 inch Thermal R&D exhaust, Tial external wastegate, Tial blow off valve, Magnecor 8.5mm wires, B&M engine oil cooler, Quaiffe limited slip diff., AWD equal length axles, all polyurethane suspension and engine mounts, Fluidyne radiator, FAL low profile fans, Baer brakes, S.S. lines, slotted and cross drilled rotors, front and rear strut bars, DSS coilovers, carbon fiber hood, have most original parts, all reciepts and maintenance, laptop included for programming have extra parts included 16G turbo, HKS VPC unit, Greddy Profec boost controller, MSD ignition, AEM ingnition, old intercooler from previous mods before AEM EMS installed...... After reading this does it seem like 340 wheel horsepowerr is possible ?? Im going to be buying this car just trying to make sure .
I know I`m not rich in the post category, but 16 psi + a 20g doesnt make 340whp. It`s barely efficient at that psi, unlike a 14b or 16g. Also - Why 550`s for all that? Any number of posts on here will show you that 550`s are maxed out (100% idc) around 300-325 whp.
And what they said about buying a built car with ~`$20k` in to too.;)
Thats why I'm telling him to steer clear.
Hell, if you've got 5k to spend on a DSM you could keep your eye out for a clean 1G with a decent body in unmolested condition for $1500-$2500. You'd still have enough money left over to do some tasteful upgrades instead of paying for someones already on the car. There are better deals out there.
