Do you need to unbolt the MM when changeing the HB/CP ???
turbotemper
203
Jan 23, 2009
Fresno, California
So the chiltons says to support the vehicle, remove fender liner, jack up the motor sightly to support it, unbolt the MM, remove the belts, then unfasten the retaining bolt. Use a jawed puller to remove pulley.
Ok so do you really need to undo the MM to get the HB/CP off? And do you need the jawed puller or can you just use the other puller that uses bolts to press it off?
Newb question: So when you're unfastening the HB/CP bolt counterclockwise, it wont f'up the timing ??? I thought the crank wasnt supposed to rotate that way?
To remove the crank pulley, take off the wheel, remove the splash shield(3 12 or 14mm bolts). Then remove the 4 little 10mm bolts holding it on. The big center crank bolt does not come out, but you can put an extension it the square hole and hold it with a socket wrench while removing the small bolts. That will stop it from rotating backwards.
You don't have to touch the motor mount. If anything, I would think raising the motor would make it harder to remove. It's unnecessary.
You don't need to remove the motor mount and you don't need a puller.
Just take off the belt and remove the four 12mm(IIRC) and it comes right off. You don't need to remove the center bolt/washer.
EDIT^^ beat me to it.
