staticbrainwash
- 1,681
- 13
- Oct 10, 2004
Midland,
Michigan
Can't be worse than aluminum. . . my lord.
Holy crap I just came here to say the same thing.
well that's all fine and dandy, but not really relevant to the subject at hand. That is about post-turbo exhausts.
No matter what you make, it will be much better than any cast manifold and cost much less than any decent header. !
Mr. Peppers did you ever finish this?
I swear i posted a link in this topic last night. It was toa great tutorial on building a tubular turbo manifold from steel plate and things called "weld els" for the tubing.
I'll post it again now and see if it dissapears this time
There's so much more great informative info on this page you'll sh!t your pants if you look through the right stuff
here's the main link
Building a Turbo Manifold
You did. It's a little sneaky, but I seemed to snag it in post #31
Anyway I'm not drunk ( wouldn't mind being though ) and that is fairly odd and or random that you bought your car from omaha.Thanks for the reply, I'm holding off for now and running this 16g until summer. Theres a speed shop not to far from me that sells bends for cheap. I have my head, and t3 flange just need those bends.
Back from the dead....
I revived this thread because its probably the most informative one regarding DIY exhaust manifolds on this forum. I have a Holset HX35 with the stock 12 cm^2 divided housing, and I want to build a divided manifold to run the stock housing (no, I don't want to run the bolt on housing). Speaking of which, if anyone knows where to buy a non wastegated housing used, let me know. You can buy them new for $195 but I'm trying to do this as cheap as possible.
I'm currently designing the manifold in Solidworks so I can get a rough idea of how much material I'll need and how it will all fit together.
My question is: what material to use?
I've decided to go with mild steel, because A. its cheaper than SS and B. I've never welded SS before. I was originally planning on using some 1.5" sch 40 pipe. You can get straight pipe and weld elbows pretty easily and for a decent price. OD is 1.900", ID is 1.610" and wall thickness is .145". After talking with a fabricator, he thought sch 40 would be too thick and suggested using some tube with .095 wall. However, I don't know if it would be thick enough, nor if I could even find it. Does anyone know what kind of dimensions are run on vendor's manifolds? (OD, ID). Of course, they are made of SS, but it will at least give me something to shoot for. Flanges will be 1/2" mild steel.
Any comments, suggestions, are appreciated.
