XO2 Tubular Exhaust Manifold
BaileyBoy
109
Mar 22, 2004
Alto, Michigan
Just searched for previous threads on this
Seems to be the only manifold listed as being constructed with SUS321 stainless steel on ebay, so I was interested in information also
I too will be awaiting to see if anybody has one
Imo, I wouldn't take the chance. Porting your stock manifold will be more than enough for a 16g but I haven't ran the manifold so I cant tell you if its worth it..
good call, i didn't even think of searching for that.
I looks a hell of a lot like the ssac manifold, and i have a good friend who has had a great history with that manifold ($250) not sure what material they used
I ran this manifold and their o2 housing. I really loved them and never had any problems for the 6 months I had the car. It held up great through the beatings I laid to it and never once cracked or had any installation problems. Go for it! :thumb:
I ran this manifold for almost a year and a half. the only complaint I have is whe it did fianlly start to change colors like all the stainless manifolds do, it turned into more of a rust look instead of the pretty goldish-purple look like the dnp gets. It never did crack and it fit up perfect.
Anthony
thanks for the pics!
and ya that is wierd that it went to a rust color...did you wipe all your grease and hand prints off before you ran it. I know that you can litterally burn a finger print into new manifolds if you leave the oils from your hand on it after an install.
I never really thought of that. that might have been the case. Other than the color though, the manifold was a good one in my opinion.
Anthony
Theres a badge/plate on the driver side (Number one cylinder) runner.. just wondering what it says?
Oh ok, No that is just Xo2Racing's little badge. Ill tell ou what. I also have there intercooler, and it is excellent craftsmanship!:thumb:
Anthony
Well that sounds good, i think i may end up getting this....im not to worried about the color of it because looks dont make you go fast LOL.
Anthony
There's a couple different knockoff tubular manifolds
Here's a comparison
Xo2 Racing
1yr Warranty, No discolored welds, other brand
Other manifold
Xo2 Racing
1yr Warranty, No Discolored Welds
Other manifold
SSAC/XSpower
Another variation called the UPC/Logic Performance
Wonder which design performs the best?
This manifold came with his ebay 16g turbo kit setup
Looks like XO2 Racing, But I believe it said XS power on that badge
Lasted over 4k miles until the engine blew
Here's a pic I made of 6 different manifolds, all arranged the same way, with slight differences in angle
As you can see, they all have some differences between each other..?
good stuff ^^ I just hope it lasts. If it turns colors I can always repolish it LOL
And if it starts cracking make friends with a good TIG welder LOL
j/k.. Seems like teh one guy liked it jsut fine. The only thing i worry with on tube headers is teh weight of teh trbo pulling on it especially when it's glowing hot from a run. buta lot of tehm do hold up well.
Do a review if you get it....after putting it through teh wringer that is :D
I had one, very temporarily. A local had a T3 version, and Hahn's adapter plate was semi-backordered, so I bought this as a temp solution to get the car on the road.
I'm not sure which craptacular eBay brand of the day it was, but the runners were so small, I can't believe the motor didn't choke to death.
Another local cracked his DSM'flanged variant. Twice. I believe it's a paper weight now.
I've done alot of research on tubular exhaust manifolds, and my conclusion is they're more trouble than they're worth. They all crack eventually (DNP included), and overheat stuff under the hood, destroying alternators, melting fans etc.. Probably the only one I would buy that doesn't cost a grand is the OBX one because it has a lifetime warranty, and when it cracks you can get a new one for free (still a pain because you have to change it out). If your building a race car you may want to go with a high dollar one, but otherwise it's ill advised.
Well I just bought a Xo2.. and I'm gonna hang a PTE SCM5031E off it.. so I'll let you know how it fairs
haha
