Dirt Oval Racing: How to make a NA Fast?
fourgsixthree33
1,244
46
Oct 25, 2010
Athens, Pennsylvania
I have done some searching about dirt oval 1G's, but most of the topics are about setup and handling. I am getting into this as I race dirt modifieds and street stocks. I am tired of seeing all these Honda's at the track with their VTECHHH and bringing home trophies every night in their FWD class.
I would like to state that this class does NOT allow forced induction and the car has to be FWD. Tracks have their own set rules about what you can and can't do with the engine. Most tracks require you to be under a certain compression (compression test).
A mostly stock NA 4G63 is going to be under-powered against the VTECH guys. I know how to make our Turbo 4G63's fast, but I am asking for your help on the NA 4G63. Here is what I am thinking.
Turbo ECU, turbo wiring harness, turbo MAF, turbo injectors, and a turbo injector resistor pack. Basically, I am looking for a turbo DSM shell and rebuild a NA 4G63.
Do I use a knock sensor? I would imagine I would need a knock sensor in order for the car to run half descent. BUT, with the turbo ECU, I will be getting a LOT more timing. Like, damn close to detonation. So with that said, would retarding the timing via the CAS be enough adjustment? Or could I run no knock sensor, thus causing the ECU to pull timing, and get the car to run half descent?
I would imagine DSMlink would be extremely useful. But would it solve all of my concerns?
Is there anything else I have not taken into consideration?
I kind of want to get a 2G turbo shell and drop in the NA 4G63. 2G's are wider, but they are also heavier. And I just think it would be really cool to have a NA 4G63 2G :rocks:
Mitch
What other cars are running in the class, and what engines if you know, Hondas, Pintos, Toyos. Mustangs?
450hp dyno proven mustang motors in open wheel modified chassis,280hp dyno proven Hondas, and talons are all that stick up front (top 8) every one else gets lapped
Mitch
Did you dyno that number??
no but I want it to be but its to pricy considering im most likely getting out of it but it will run with 280hp dyno proven Hondas so its got to be close
Mitch
The car originally posted on hear he runs with them some he is back of the fast pack
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
