gsx-How to make a fast street car running a green turbo ?
BrianGSX
Feb 7, 2008
Wroclaw, Europe
Hello, at the beginning i’d like to appologise if I copy an already existing topic, but I ve searched very long and havn’t found answers to my questions. :confused: I m from Poland were we have some strong 2g GSX’s but this subject is still crawling. That’s why I m asking you for help, because of your bigger experience.
I ll start from showing you my current stage:
MODEL:
Mitsubishi Eclipse GSX 1996
Modifications :
Engine : 2.0 16v turbo ( 4G63T) :hellyeah:
Turbo:
FP Green ,bov Tial ,
Air Intake System:
K&N filter , intercooler
Exhaust system:
3" stainless steel from the engine, Wastegate 41mm Tial
Cooling :
Radiator Fluidyne 38mm,Radiator Hoses Samco ,2 x Slim Fun Maradyne High Performance 12"
Injection system :
550 ccm injectors, Walbro 255l/h fuel pump
Electronics :
Apexi S-AFC II, turbotimer HKS Type 1, NGK sparks, Taylor 10,4 mm Ignition Wires
Transmission :
Greddy Kevlar timing belts and balance belts , manual transmission + short shifter + ACT 2900 ibs + LSD
Suspension :
Kayaba GR2 shocks , front and rear Megan Racing Strut Bars
Plans :
Strocker kit 2,4 lit SBR Stage II
My question is about :
Which camshafts would you suggest ? WTF
- Brian Crower
-Force Performance
-HKS
-Crower
-CompCams
-Greddy
Maybe some others, i m thinking about the 272/272 configuration, what do you think ?
Which Intake manifold ?
-Magnus
-JMF
exhaust manifold – ram type like DN Performance or a short one like FP
What do you think about the flywheel, I want a compromise, don’t want the car to act nervous, thinking about ACT ProStreet
Cam Gears ?
HKS
Fidanza
Greddy
I’d like to have a street car with a strong bottom
All suggestions and proposals are more than welcome.
The goal is to gain the max power from the green turbo :hellyeah:
FP green wont get you anywhere near 600hp+ The green XL (red size comp wheel with green size turbine the biggest green currently out there iirc) maxed out at 400hp on pump93, with 100% methanol injection. Yes this is one data point, but I believe it was from a dyno tune, and I assume any dyno tuner will be half-decent and get within the ballpark at least.
I think green is a 350-450-500 AWHP turbo depending on fuel. PumpGas will get the lower range, e85 and/or meth will go higher and I suppose ultra race gas + cocaine will get you to 500. Did you even get ECMlink yet?
Yes, i know that :thumb: Finally engine will be powered by the larger turbocharger :hellyeah: controlled by EMS :sneaky: therefore, I think :aha:that with larger turbo, head will be crucial :thumb:
Fancy headwork is not required for what you are trying to do. That money would be better spent elsewhere at this stage in your build.
You didn't answer his question.. do you have a proper way to tune the car? Or are you still on that S-AFC listed in your first post on this thread from 2009?
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
