did i get to cold of plugs?
britdog
153
Jun 27, 2011
tiffin, Ohio
Okay for mods i have a 272 cams, 16g turbo pushing about 14 psi. Walbro 255, stock injectors, tubular manifold 3 inch turbo back and a front mount. Are ngk bpr9es to cold?
And get BR7ES, non-projected since the higher boost, which cause higher compression has a tendency to blow out the spark on projected plugs.
You get that spark on top of the combustion chamber, and the blowout possibility is drastically reduced.
That way, you can still use the .028 gap setting.
Bpr7es are projected. Br7es are not. Get Br7es.
Bpr7es are projected. Br7es are not. Get Br7es. Most of the time, the auto parts stores wont have the br7es in stock. Order them.
