2G deceleration noise diagnosis GSX manual
MarksGTR
4
Nov 2, 2021
Peabody, Massachusetts
Hello!
I'm excited to share that I've finally acquired my childhood dream car, a '99 GSX, and what's even more thrilling is that it's all OEM with no modifications! However, shortly after the purchase, I noticed an unusual noise emanating from the transmission area, specifically the 5-speed manual transmission.
In my quest to resolve this issue, I took it to my trusted technician, who has extensive experience in diagnosing and troubleshooting automotive problems. We embarked on a comprehensive diagnostic journey, ruling out potential causes one by one. Here's what we've discovered so far:
  1. We confirmed that it's not a transmission problem by testing it with another transmission, and the issue persisted.
  2. The noise isn't originating from the carrier bearings; they've been checked and are in good condition.
  3. We even disconnected the driveshaft to eliminate the rear as a potential source of the noise, and it wasn't the culprit.
  4. We upgraded the clutch from a lower-quality one to an Act clutch and installed a lightweight flywheel, but unfortunately, this didn't resolve the issue either.
At this point, we're still trying to pinpoint the exact source of the noise and resolve it. If you have any insights or suggestions, please feel free to share them. Your input would be greatly appreciated.
Great call @Mech Addict , but
  1. We even disconnected the driveshaft to eliminate the rear as a potential source of the noise, and it wasn't the culprit.
Is it worse during decel in gear? Do you hear it coasting in neutral? Fluid levels all good? Sprung clutch disk or solid hub?
Curious how you tested without a drive shaft. Did you modify the center LSD to make it solid? Was the transfer case still attached?
A loose preload of the pinion bearing in the rear end could be a suspect, but not sure how that would play out without a driveshaft. For that matter, loose preload or worn bearing(s) anywhere from the trans to the rear end could be to blame.
A spare trans could have the same issue as this is an issue that plagues a lot of DSMs.
Great questions! correct decel in gear, very light noise (livable). do not hear it durning coasting in neutral.
In the air, nothing as be modified. Yes gear oil is new and fluid is good. Great points, I will still check.
Trans that i have was rebuilt is all oem parts as we thought it was a trans issue. It was not.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
