dead ECU?
Glliw
471
3
Dec 18, 2005
Panama City Beach, Florida
So i was going through and double checking SAFCII wiring, and found two to be backwards. I fixed the problem and went to turn the car on. I forgot to plug the plug back into the ecu(i know, stupid) and the car would just crank. My idiot self realized this and plugged it back in. I proceeded to try to start it again and all i could get was one crank. Its real drawn out like...2 seconds long and every second or two it would crank again. What did I hurt?
I was hoping it would be something simple like that, this battery has been known to give me crap before. I just don't have the money to get a good optima battery right now. I have to wait til somebody else gets home to be able to charge it though. In the meantime, any other ideas?
Update: I'll just lay down some points here to help you guys help me.
It can be jumpstarted/push started
The battery voltage read from the SAFC stays between 13 and 13.8 when the engine is running.
A voltage of 8.9-9.2 from the SAFC when in the ON position.
If it is cranked, I get one long drawn out crank. Then a couple more after a few seconds in the same fashion.
When jumpstarted, it starts right up.
Even 30 seconds after being jumped, if I turn it off and try to crank again, the original long drawn out crank appears again.
I'm thinking dead battery, and going to pick up an optima tomorrow. Could a bad SAFC grounding cause this? I tapped the ground wire for the ecu with the brown first and black further away, so I can't see that being the problem. But its the only thing that I've done to the car recently. Then again, why would I have good battery voltage and not be able to start, but be able to jumpstart it?
Your battery may show good voltage but have a dead cell. take it out and take it to your local parts store and have them do a load test on it. also i thought my battery was shot and instead of testing it i went out and bought a new 1 and to my surprise my starter drug out even longer when starting and sometimes not starting. So i would also try taking off your starter (which is a pain) and blow it out. That fixed my starting problems for now.LOL
Ah crap, I've always dreaded the day that I would have to take that damn thing out. I will first try the battery way however. But how can the starter be the culprit when being jumpstarted, it starts just fine?
It puts more voltage to the starter. instead of 13volts it getting twice that. also make sure your wire is tight on your starter to. That is something else i found when i took my starter off. which dummy me shouldve checked first but went thru all the trouble of taking it off:mad:
Glliw said:
Update:
8.8-9.2 is not good voltage. It should read in the 12's when car is turned off. Def sounds like a bad battery.
My battery voltage with a brand new battery only shows 10-11 volts when the car isnt running bc you have voltage lost between the battery and the wires inside the car. but that is why i said to have the battery checked b4 messing with the starter
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
