Datalog : evo3 @ 20psi , 650's, 190, eprom maft and safc2
CHItown90gst
57
Aug 13, 2005
Chicago, Illinois
Well, since I cannot post in the tuning section yet, I decided to post my log here. Mods are in my profile. SAFC setting are zero'd out because I have a keydriver chip for my EPROM. Maft are set to stock. I see knock in the higher RPM's. I think its because im creeping(stock unported 02 housing). I am also running rich according to my wideband. Whats going on?
Omar
EDIT: I tried using the excel code bit from one of the articles, but I kept on getting linked by some spam crap so I just saved it as a picture.
Turn the boost down to 15psi and start from there. From my experience with the 1g timing and no timing control 20psi is a little too much for the 16g on pump gas. Tune the wbo2 to around a 11.1 afr at 15psi. Slowly turn up boost till you get knock and keep the afr around 11.1. Once you see some knock pull the boost back to where there was no knock. I would guess the most you can get is 16-18psi without knock.
Ah yes. It fluctuates from around 10 or so. Im going to try and lean it out a little and lower the boost to 15. Hopefully It wont creep to bad. I'll post another log later today.
