1G Dash wiring
Mutzky
May 26, 2021
Črni vrh, Europe
Hello guys!
I have an 1993 plymouth laser rs turbo awd that i'm restoring. It had hole in the windsheild so the inside got destroyed. While i was restoring the dash cables looked nasty so i replaced them from my 1992 mitsubishi eclipse dohc n/t. Will it work on the turbo awd model. I tried hooking it up and if i crank the boost gauge goes in the middle.
It shouldnt matter there was no diffrence if i recall doing what you did. if the boost gauge works then your fine.
I will tell you from my car originally being a non turbo car, there is no wire in the nt harness to the ecu for the factory boost gauge. Never tore that deep in but with that being said I wouldn’t be shocked if the wire isn’t there behind the dash going to the cluster.
I still instaled it as the old wiring was nasty and boost gauge seems to work. The only problem i have rn is that when in try to crank the engine, not all lights light up like seat belt warning light and cruise control (i don't remember correctly which lights dont light up). Should all lights light up when i crank the engine?
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
