KC2RPM
- 48
- 2
- Feb 3, 2009
Watertown,
New York
Ok well first of all its not my dimmer switch. I have tried all that. The problem im having is im not getting power to the dimmer... But anyways there are so many cut wires underneith the dash that I dont even know where to begin. Can you guys look at your cars and try to give me an idea as to what goes where??!!! This is extremely fustrating!
Ok so this a red wire with a white stripe that I have no clue where its suppose to go along with the green/white wire that has a connector which reads no volts when the lights are turned on. It is to the right of the fusebox. As you can see the clutch pedal is beside the wires.
This one, there is some sort of connector that is just hanging down. Disregard the disconnected clutch safety switch. I have that one disconnected on purpose. There is not a place for this behind the white fusebox up top either, I have already checked. It reads 12V constant. There are another two wires red/white that are going nowhere as you all can tell.
The third is In my steering column. What do these two bent connectors go to?
I forgot to mention that all my fuses are good.
I have more pictures found here on my photobucket. Pictures by KC2RPM - Photobucket
