Need help to identify cut wires?
rixcidia
280
Dec 5, 2007
Somewhere in BC,
Hey guys so I was under my car working on the turbo and looked we're the alternator is and noticed the wire harness attached in that location I seen there to separate wires that have been cut and I can't find we're they belong here's some pics of the two wires please let me know what you think thanks,
Rix
Sorry I forgot to attach them haha here they are,
Rix
Second picture is the wire that goes to the oil pressure sender. It's the signal that operates the stock oil pressure gauge in the instrument cluster. Shown here, it's the wire that attaches to the silver sensor, bottom *right. And the plastic connector should clip into the oil filter housing
First picture may be for the oil pressure switch, do you see a sensor like the one pictured in the link, top left?
Ok cool thanks are those important to have connected and also were would the location be to connect them because I don't see the place to solder the wire back,
Rix
I don't have that spot where that red connector on your pic shows mine have noting attached to it.
Rix,
Rix
Rix,
I got my directions mixed up on accident. The second picture is the wire that goes to the far right sensor, not small sensor left
First picture may be the wire that goes to the oil pressure dummy light switch. Easy way to tell, when you flip the keys to run, does the oil light stay on until you start it?
I'm not sure if it does I'll have to check it out in the morning but I made a mistake I do have the spot there were you have the red connector connected mine is empty with noting connected to it and that other wire I can't tell we're it connects to,
Rix.
