1G cruise control cable to throttle body nut
Julio_1G
90
6
May 12, 2016
Houston, Texas
I'm missing the nut that holds the cable connected to the throttle body and whenever I push down the gas pedal that part just pops out because there is nothing holding it down. So what in asking is does someone have a part number or any links to where I can find that part so it can hold it in place.
that nut in the picture is the one I'm looking for but I don't know what's it's called so I don't know how to find the thread size for
If you only have the piece that connects to the throttle cable, you are missing much more than a nut. I would also bet the shaft seal leaks quite a bit from your photo. My advice would be to buy a used unit on the classifieds to get the parts you are missing and rebuild it. Here is a tutorial that is pretty handy: (you can also use it to see what else your missing)
http://www.plymouthlaser.com/tbor.htm
If you would prefer to buy one already rebuilt, check out http://throttlebodys.com
I also have 2 pieces of springs. Thanks for the link also, helped me figure out that I am missing more than what I hoped would be just a nut
