Crank pulley split
bcjjones
509
6
Nov 3, 2011
Austin, Texas
So from what I've read, the crank pulley can actually split? As in the part that the belts wrap around seperates from the middle part that bolts on to the crank.
Was I reading that correctly?? Seems crazy to me
Well mine split, got lucky and thats all that happened. Did cause timing to jump and no bent valves. I guess though, that JB welding it back together is a stupid idea? Because isnt it a dampening pulley?
I had one slit too bro. Lucky for me I have a couple extra laying around. So my advise is swap a new one in or find a good used one. Check for people parting out cars in classifieds.
Are you talking about the harmonic balancer?
Are you talking about the harmonic dampener?
To the OP... Typically when they go out, it won't effect timing. Just get a new dampener and you're good to go. But don't get an aluminum one or solid one. They don't absorb crank vibrations and can cause the crank to break.
Yea he's talking about the harmonic balancer. Don't JB weld it. You got lucky this time, but why take the risk of it breaking and ruining your motor? That JB weld will end up costing you so much more in the future. A friend of mine bent all his valves, recently, because his pulley separated.
Go to napa and grab a new one and never worry about it again.
Really tit for tat buddy good job
Just seems crazy that they arent more sturdy. I never really noticed any signs of it going bad but I guess there really arent any? Other then maybe chirping or something but never had any of that happening.
And to Flash1970, the only reason I was thinking it would effect timing is if it got jamed up against wheel well and caused the timing to jump.
Ill just get a new/used one. Thanks fellas
They are sturdy, but rubber can't last forever. And bonded rubber dampers are far cheaper than a fluid based damper from production standpoint, so that's why Mitsu went that route.
If it's a relativily stock car, go with another bonded rubber damper and you'll be fine for another 10-15 years. If it's a performance application, go with soomething that has a solid shell and is tuned for more power and RPM.
