crank pulley?
ok if i replace the crank with a oem crank can i still get lighter alt. and water pump and
power steering? because the lighter crank pulleys are not dampened
You mean OEM crank pulley right? Yes you want an OEM crank pulley, or some people have had success with a Fluidamper pulley. Stay away from the non-dampened aluminum "harmonic balancer" (using the term loosely), it's like giving your engine time release cyanide tablets.
As for the other pulleys, if they fit, I suppose you can use whichever ones you want with your OEM harmonic balancer. Why not?
thanks were can i get the fluidamper pulley
