Crank & baring questions...
Powers_Vang
161
Mar 29, 2004
Sand Village, Asia
I was wonding that if I bought the light weight crank from Buscher & new Mitsubishi barings...would that help stop crankwalk? I've read almost all postings & articles about crankwalk but yet nothing of after market parts solution.
I'm thinking that I might have crankwalk & I'm doing research. I've read some articles about the 2g bottom end not getting enough oil & other articles say that the crank was machined off a little.
I have a complete 90 GSX on my hands with a blown head gasket. I'm debating between either just fixing my car OR doing a swap.
If I do a swap will the 6 bolt line up with the 2g tranny. Some say yes & others say there will be drillin involved & some screw holes need to be filled & re-tapped. So which is it?
Thanks..I'm sort of confused which way to go. Don't point be back to the crankwalk section cause it mostly complaints & experiences. I might have crankwalk & I'm looking for the best soltution.
Nope. Or, maybe. Trouble is that no one knows what the trouble is. I've heard about three theories that I don't just reject as being either occasional-case, or absurd: Bad metal, bad maching, or bad machining of not enough metal. The oil squiter idea doesn't convince me, nor do I generally blame the Silent Shafts, although in those cases where it's been the cause, it's been the cause.
There's no more a "stop" to crankwalk than there is a "cause".
Many, many, many 7-bolt motors are going on and on and on.
Some help. :rolleyes:
easy answer do the block swap
most people will be politicians with the crank walk problem, avoid the issue completely is the correct answer.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
